Subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$, Jacobi polynomials and complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2019
In an earlier article together with Carlos D'Andrea [BDKSV2017], we described explicit expressions for the coefficients of the order-$d$ polynomial subresultant of $(x-\alpha)^m$ and $(x-\beta)^n $ with respect to Bernstein's set of polynomials $\{(x-\alpha)^j(x-\beta)^{d-j}, \, 0\le j\le d\}$, for $0\le d<\min\{m, n\}$. The current paper further develops the study of these structured polynomials and shows that the coefficients of the subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$ with respect to the monomial basis can be computed in linear arithmetic complexity, which is faster than for arbitrary polynomials. The result is obtained as a consequence of the amazing though seemingly unnoticed fact that these subresultants are scalar multiples of Jacobi polynomials up to an affine change of variables.
SubresJacobi.pdf (308.98 Ko) Télécharger le fichier
hal-01966640 , version 1 (29-12-2018)
hal-01966640 , version 2 (10-10-2019)
Domaine public
  • HAL Id : hal-01966640 , version 1
Alin Bostan, T Krick, A Szanto, M Valdettaro. Subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$, Jacobi polynomials and complexity. Journal of Symbolic Computation, inPress. ⟨hal-01966640v1⟩
52 Consultations
330 Téléchargements
