Expectation-Maximization for Speech Source Separation using Convolutive Transfer Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue CAAI Transactions on Intelligent Technologies Année : 2019
This paper addresses the problem of under-determinded speech source separation from multichannel microphone singals, i.e. the convolutive mixtures of multiple sources. The time-domain signals are first transformed to the short-time Fourier transform (STFT) domain. To represent the room filters in the STFT domain, instead of the widely-used narrowband assumption, we propose to use a more accurate model, i.e. the convolutive transfer function (CTF). At each frequency band, the CTF coefficients of the mixing filters and the STFT coefficients of the sources are jointly estimated by maximizing the likelihood of the microphone signals, which is resolved by an Expectation-Maximization (EM) algorithm. Experiments show that the proposed method provides very satisfactory performance under highly reverberant environments
ctf_em.pdf (448.93 Ko) Télécharger le fichier
hal-01982250 , version 1 (15-01-2019)
Xiaofei Li, Laurent Girin, Radu Horaud. Expectation-Maximization for Speech Source Separation using Convolutive Transfer Function. CAAI Transactions on Intelligent Technologies, 2019, 4 (1), pp.47 - 53. ⟨10.1049/trit.2018.1061⟩. ⟨hal-01982250⟩
132 Consultations
278 Téléchargements
