Vision-Based Control and Stability Analysis of a Cable-Driven Parallel Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2019
In Cable-Driven Parallel Robots (CDPRs) rigid links are substituted by flexible cables. This change in actuation allows for a large workspace with a high payload to weight ratio, among other appealing characteristics. However, the accuracy for such systems needs to be improved to truly outperform classical parallel robots. A possible and not yet well studied solution is the use of vision-based control for CDPRs. This paper deals with the stability analysis of such a control scheme with regard to uncertainties lying both in the analytical models and the experimental setup. Two CDPRs are analyzed as illustrative examples. The results obtained show the system's robustness with respect to uncertainties.
IEEE_RA-L_2019_HAL_Zake_Chaumette_Pedemonte_Caro.pdf (1.8 Mo) Télécharger le fichier
hal-01987856 , version 1 (29-01-2019)
Zane Zake, François Chaumette, Nicolò Pedemonte, Stéphane Caro. Vision-Based Control and Stability Analysis of a Cable-Driven Parallel Robot. IEEE Robotics and Automation Letters, 2019, 4 (2), pp.1029-1036. ⟨10.1109/lra.2019.2893611⟩. ⟨hal-01987856⟩
336 Consultations
862 Téléchargements
