Collecting Network Evidence Using Constrained Approximate Search Algorithms
Intrusion detection systems are defensive tools that identify malicious activities in networks and hosts. In network forensics, investigators often study logs that store alerts generated by intrusion detection systems. This research focuses on Snort, a widely-used, open-source, misuse-based intrusion detection system that detects network intrusions based on a pre-defined set of attack signatures. When a security breach occurs, a forensic investigator typically starts by examining network log files. However, Snort cannot detect unknown attacks (i.e., zero-day attacks) even when they are similar to known attacks; as a result, an investigator may lose evidence in a criminal case.This chapter demonstrates the ease with which it is possible to defeat the detection of malicious activity by Snort and the possibility of using constrained approximate search algorithms instead of the default Snort search algorithm to collect evidence. Experimental results of the performance of constrained approximate search algorithms demonstrate that they are capable of detecting previously unknown attack attempts that are similar to known attacks. While the algorithms generate additional false positives, the number of false positives can be reduced by the careful choice of constraint values in the algorithms.
Informatique [cs]
