Kinetic Signature of Cooperativity in the Irreversible Collapse of a Polymer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2018
We investigate the kinetics of a polymer collapse due to the formation of irreversible cross-links between its monomers. Using the contact probability P(s) as a scale-dependent order parameter depending on the chemical distance s, our simulations show the emergence of a cooperative pearling instability. Namely, the polymer undergoes a sharp conformational transition to a set of absorbing states characterized by a length scale ξ corresponding to the mean pearl size. This length and the transition time depend on the polymer equilibrium dynamics and the cross-linking rate. We confirm experimentally this transition using a DNA conformation capture experiment in yeast.
Xlink_Review_AL_VFS_JM.pdf (807.1 Ko) Télécharger le fichier
hal-01992814 , version 1 (24-01-2019)
Paternité
Vittore F Scolari, Guillaume Mercy, Romain Koszul, Annick Lesne, Julien Mozziconacci. Kinetic Signature of Cooperativity in the Irreversible Collapse of a Polymer. Physical Review Letters, 2018, 121 (5), pp.057801. ⟨10.1103/PhysRevLett.121.057801⟩. ⟨hal-01992814⟩
53 Consultations
91 Téléchargements
