Distributed Community Detection via Metastability of the 2-Choices Dynamics
We investigate the behavior of a simple majority dynamics on networksof agents whose interaction topology exhibits a community structure. Byleveraging recent advancements in the analysis of dynamics, we prove that,when the states of the nodes are randomly initialized, the system rapidlyand stably converges to a configuration in which the communities maintaininternal consensus on different states. This is the first analytical resulton the behavior of dynamics for non-consensus problems on non-completetopologies, based on the first symmetry-breaking analysis in such setting.Our result has several implications in different contexts in which dy-namics are adopted for computational and biological modeling purposes.In the context ofLabel Propagation Algorithms, a class of widely usedheuristics forcommunity detection, it represents the first theoretical re-sult on the behavior of a distributed label propagation algorithm withquasi-linear message complexity. In the context ofevolutionary biology,dynamics such as the Moran process have been used to model the spreadof mutations in genetic populations [LHN05]; our result shows that, whenthe probability of adoption of a given mutation by a node of the evolu-tionary graph depends super-linearly on the frequency of the mutationin the neighborhood of the node and the underlying evolutionary graphexhibits a community structure, there is a non-negligible probability for apecies differentiation to occur.
2_Choices_Metastability___AAAI19___HAL_version.pdf (386.58 Ko)
Télécharger le fichier
