One more step toward a push-pull strategy combining both a trap crop and plant volatile organic compounds against the cabbage root fly Delia radicum. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Environmental Science and Pollution Research Année : 2018
The "push-pull" strategy aims at manipulating insect pest behavior using a combination of attractive and repulsive stimuli using either plants derived volatile organic compounds or insect host plant preferences. In a field experiment using broccoli as a crop, we combined in a "push-pull" context the oviposition deterrent effect of dimethyl disulfide and the attractive effect of a Chinese cabbage strip enhanced with Z-3-hexenyl-acetate. The push component dimethyl disulfide reduced Delia radicum L. (Diptera: Anthomyiidae) oviposition on broccoli by nearly 30%, and applying Z-3-hexenyl-acetate in the pull component of Chinese cabbage increased it by 40%. Moreover, pest infestation was 40% higher in Chinese cabbage compared to broccoli and parasitism by Trybliographa rapae Westwood (Hymenoptera: Figitidae) was four times higher on this trap plant. In addition, lab experiments confirmed that Chinese cabbage is a more suitable host plant than broccoli for the cabbage root fly. Taken together, our results demonstrate the technical possibility of using a push-pull strategy to manipulate the egg-laying behavior of D. radicum in the field.
Fichier non déposé
hal-02010138 , version 1 (06-02-2019)
Fabrice Lamy, Sébastien Dugravot, Anne-Marie Cortesero, Valérie Chaminade, Vincent Faloya, et al.. One more step toward a push-pull strategy combining both a trap crop and plant volatile organic compounds against the cabbage root fly Delia radicum.. Environmental Science and Pollution Research, 2018, 25 (30), pp.29868-29879. ⟨10.1007/s11356-017-9483-6⟩. ⟨hal-02010138⟩
38 Consultations
0 Téléchargements
