Practical Cryptographic Data Integrity Protection with Full Disk Encryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Full Disk Encryption (FDE) has become a widely used security feature. Although FDE can provide confidentiality, it generally does not provide cryptographic data integrity protection. We introduce an algorithm-agnostic solution that provides both data integrity and confidentiality protection at the disk sector layer. Our open-source solution is intended for drives without any special hardware extensions and is based on per-sector metadata fields implemented in software. Our implementation has been included in the Linux kernel since the version 4.12.
472722_1_En_6_Chapter.pdf (906.69 Ko) Télécharger le fichier
hal-02023745 , version 1 (21-02-2019)
Paternité
Milan Brož, Mikuláš Patočka, Vashek Matyáš. Practical Cryptographic Data Integrity Protection with Full Disk Encryption. 33th IFIP International Conference on ICT Systems Security and Privacy Protection (SEC), Sep 2018, Poznan, Poland. pp.79-93, ⟨10.1007/978-3-319-99828-2_6⟩. ⟨hal-02023745⟩
112 Consultations
340 Téléchargements
