A new McKean-Vlasov stochastic interpretation of the parabolic-parabolic Keller-Segel model: The two-dimensional case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In Talay and Tomasevic [20] we proposed a new stochastic interpretation of the parabolic-parabolic Keller-Segel system without cutoff. It involved an original type of McKean-Vlasov interaction kernel which involved all the past time marginals of its probability distribution in a singular way. In the present paper, we study this McKean-Vlasov representation in the two-dimensional case. In this setting there exists a possibility of a blow-up in finite time for the Keller-Segel system if some parameters of the model are large. Indeed, we prove the well-posedness of the McKean-Vlasov equation under some constraints involving a parameter of the model and the initial datum. Under these constraints, we also prove the global existence for the Keller-Segel model in the plane. To obtain this result, we combine PDE analysis and stochastic analysis techniques.
article-ks-d2.pdf (303.8 Ko) Télécharger le fichier
hal-02044262 , version 1 (21-02-2019)
hal-02044262 , version 2 (01-08-2019)
Milica Tomasevic. A new McKean-Vlasov stochastic interpretation of the parabolic-parabolic Keller-Segel model: The two-dimensional case. 2019. ⟨hal-02044262v1⟩
409 Consultations
385 Téléchargements
