Haptic techniques for browsing sound maps organized by similarity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This demo paper showcases haptic techniques for browsing sound maps organized by content-based similarity. Our system Freesound Tracker forks the Freesound Explorer application inside a web browser augmented with haptic capabilities using the Chai3d library that we modified to support Haply haptic devices, ours configured with a 2-DOF pantograph mechanism. A first technique enhances the exploratory navigation of sound maps by adding physical effects, such as: magnetizing the pointer to its closest sound item, rendering viscosity when hovering items. A second technique assists loop-based musical creation by having user-defined sound paths followed by the force-feedback pointing device.
demo3.pdf (232.39 Ko) Télécharger le fichier
hal-02050235 , version 1 (27-02-2019)
  • HAL Id : hal-02050235 , version 1
Christian Frisson, Colin Gallacher, Marcelo M. Wanderley. Haptic techniques for browsing sound maps organized by similarity. International Workshop on Haptic and Audio Interaction Design - HAID2019, Mar 2019, Lille, France. ⟨hal-02050235⟩
Collections
TDS-MACS HAID2019
188 Consultations
43 Téléchargements
