Field-Reliability Predictions Based on Statistical System Lifecycle Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Reliability measures the ability of a system to provide its intended level of service. It is influenced by many factors throughout a system lifecycle. A detailed understanding of their impact often remains elusive since these factors cannot be studied independently. Formulating reliability studies as a Bayesian regression problem allows to simultaneously assess their impact and to identify a predictive model of reliability metrics.The proposed method is applied to currently operational particle accelerator equipment at CERN. Relevant metrics were gathered by combining data from various organizational databases. To obtain predictive models, different supervised machine learning algorithms were applied and compared in terms of their prediction error and reliability. Results show that the identified models accurately predict the mean-time-between-failure of devices – an important reliability metric for repairable systems - and reveal factors which lead to increased dependability. These results provide valuable inputs for early development stages of highly dependable equipment for future particle accelerators.
472936_1_En_7_Chapter.pdf (539 Ko) Télécharger le fichier
hal-02060048 , version 1 (07-03-2019)
Paternité
Lukas Felsberger, Dieter Kranzlmüller, Benjamin Todd. Field-Reliability Predictions Based on Statistical System Lifecycle Models. 2nd International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2018, Hamburg, Germany. pp.98-117, ⟨10.1007/978-3-319-99740-7_7⟩. ⟨hal-02060048⟩
62 Consultations
99 Téléchargements
