An Algebra with a Fixpoint Operator for Distributed Data Collections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Nils Gesbert
  • Fonction : Auteur
  • PersonId : 958488
Pierre Genevès
Nabil Layaïda
We present an algebra with a fixpoint operator which is suitable for modeling computations with distributed collections found in big data frameworks. We show that under reasonable conditions this fixpoint can be evaluated by parallel loops with one final merge rather than by a global loop requiring network overhead after each iteration. We also show when and how filters can be pushed through recursive terms, proposing optimisation rules. This makes it possible to develop algebraic optimizations in the presence of recursion, in a way which is especially suited for query optimizers and compilers targeting big data frameworks.
article.pdf (662.59 Ko) Télécharger le fichier
hal-02066649 , version 1 (13-03-2019)
hal-02066649 , version 2 (16-10-2020)
hal-02066649 , version 3 (16-10-2020)
hal-02066649 , version 4 (16-10-2020)
hal-02066649 , version 5 (02-03-2021)
hal-02066649 , version 6 (24-05-2022)
  • HAL Id : hal-02066649 , version 1
Sarah Chlyah, Nils Gesbert, Pierre Genevès, Nabil Layaïda. An Algebra with a Fixpoint Operator for Distributed Data Collections. 2019. ⟨hal-02066649v1⟩
505 Consultations
577 Téléchargements
