Balancing Stakeholder Interests: Socio-Technical Perspectives on Smart Working Practice
The advantages put forward for so-called Smart working may sound very appealing. However, it is unlikely that all stakeholder groups involved will benefit to the same extent, if at all. Many initiatives that seem to be aimed at development of Smart work systems can be seen to be flawed, since they are suggested to support empowerment but are expressed in terms of pre-defined ‘best practice’. This inherent paradox leads to consideration of ways in which innovation could occur that would lead to genuinely Smart systems, harnessing Smart technologies and empowering engaged actors to co-create meaningful practice in pursuit of professional excellence. An open, socio-technical systems approach is suggested to be the way forward.
