Consensus and Flocking in Cooperative Systems with Random Communication Failures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We study sufficient conditions for convergence to consensus and flocking of non-linear multi-agent systems subject to random-in-time communication failures. Our approach is based on Lya-punov methods adapted to this non-stationary setting , under a persistence of excitation condition. This assumption has an interpretation in terms of average connectedness of the interaction graph.
CS_ComFail.pdf (648.61 Ko) Télécharger le fichier
Format : Figure, Image
hal-02087941 , version 1 (02-04-2019)
hal-02087941 , version 2 (25-10-2019)
hal-02087941 , version 3 (28-05-2020)
hal-02087941 , version 4 (21-09-2020)
hal-02087941 , version 5 (03-05-2021)
  • HAL Id : hal-02087941 , version 1
Benoît Bonnet, Emilien Flayac, Francesco Rossi. Consensus and Flocking in Cooperative Systems with Random Communication Failures. 2019. ⟨hal-02087941v1⟩
362 Consultations
134 Téléchargements
