Preprints, Working Papers, ...
Simulation of hyperelastic materials in real-time using deep learning
Abstract : The finite element method (FEM) is among the most commonly used numerical methods for solving engineering problems. Due to its computational cost, various ideas have been introduced to reduce computation times, such as domain decomposition, parallel computing, adaptive meshing, and model order reduction. In this paper we present U-Mesh: a data-driven method based on a U-Net architecture that approximates the non-linear relation between a contact force and the displacement field computed by a FEM algorithm. We show that deep learning, one of the latest machine learning methods based on artificial neural networks, can enhance computational mechanics through its ability to encode highly non-linear models in a compact form. Our method is applied to two benchmark examples: a cantilever beam and an L-shape subject to moving punctual loads. A comparison between our method and proper orthogonal decomposition (POD) is done through the paper. The results show that U-Mesh can perform very fast simulations on various geometries, mesh resolutions and number of input forces with very small errors.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02097119
Contributor : Andrea Mendizabal Connect in order to contact the contributor
Submitted on : Wednesday, May 22, 2019 - 7:52:30 PM
Last modification on : Saturday, November 9, 2019 - 1:46:19 AM
File
umesh_paper.pdf
Identifiers
  • HAL Id : hal-02097119, version 2
Citation
Andrea Mendizabal, Pablo Márquez-Neila, Stéphane Cotin. Simulation of hyperelastic materials in real-time using deep learning. 2019. ⟨hal-02097119v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
