Visualizing the Template of a Chaotic Attractor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
Chaotic attractors are solutions of deterministic processes, of which the topology can be described by templates. We consider templates of chaotic attractors bounded by a genus-1 torus described by a linking matrix. This article introduces a novel and unique tool to validate a linking matrix, to optimize the compactness of the corresponding template and to draw this template. The article provides a detailed description of the different validation steps and the extraction of an order of crossings from the linking matrix leading to a template of minimal height. Finally, the drawing process of the template corresponding to the matrix is saved in a Scalable Vector Graphics (SVG) file.
olszewski2018visualizing.pdf (1.63 Mo) Télécharger le fichier
hal-02099518 , version 1 (15-04-2019)
Maya Olszewski, Jeff Meder, Emmanuel Kieffer, Raphaël Bleuse, Martin Rosalie, et al.. Visualizing the Template of a Chaotic Attractor. Graph Drawing and Network Visualization, , pp.106-119, 2018, 26th International Symposium, GD 2018, Barcelona, Spain, September 26-28, 2018, Proceedings, 978-3-030-04413-8. ⟨10.1007/978-3-030-04414-5_8⟩. ⟨hal-02099518⟩
47 Consultations
76 Téléchargements
