Mesh Generation and Flow Simulation in Large Tridimensional Fracture Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
Fractures in the Earth's subsurface have a strong impact in many physical and chemical phenomena, as their properties are very different from those of the surrounding rocks. They are generally organized as multi-scale structures, which can be modeled by Discrete Fracture Networks (DFNs) that may contain hundreds of thousands of ellipses in the tridi-mensional space. This paper presents our approach to generate meshes of such large DFNs and to simulate single-phase flow problems using these meshes.
laugpichot2018_REV.pdf (1.96 Mo) Télécharger le fichier
hal-02102811 , version 1 (17-04-2019)
hal-02102811 , version 2 (17-12-2019)
Paternité
  • HAL Id : hal-02102811 , version 2
Patrick Laug, Géraldine Pichot. Mesh Generation and Flow Simulation in Large Tridimensional Fracture Networks. IMACS Series in Computational and Applied Mathematics, 22, , pp.71-80, 2019. ⟨hal-02102811v2⟩
191 Consultations
323 Téléchargements
