Density and excess volume for four systems involving eugenol and furan - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Solution Chemistry Année : 2019
Density and speed of sound measurements have been performed, at atmospheric pressure, using an Anton Paar digital vibrating tube densitometer for pure ethanol, 1-Octanol, n-hexane, furan and eugenol, from 278.15 to 323.15 K and for binary mixtures of furan + ethanol, furan + 1-Octanol, eugenol + 1-Octanol and eugenol + n-hexane from 278.15 to 323.15 K. Excess molar volumes were calculated and compared. The Redlich Kister correlation was used to correlate the data. In order to identify the most relevant molecular interaction which contribute to the excess molar volume, the Prigogine Flory Patterson theory was applied to correlate and predict the excess molar volume of the mixtures.
Publi VE Journal of Solution Chemistry 2019.pdf (1.56 Mo) Télécharger le fichier
hal-02104193 , version 1 (19-04-2019)
Christophe Coquelet, Eric Auger, Alain Valtz. Density and excess volume for four systems involving eugenol and furan. Journal of Solution Chemistry, 2019, 48 (4), pp.455-488. ⟨10.1007/s10953-019-00870-6⟩. ⟨hal-02104193⟩
171 Consultations
504 Téléchargements
