There's No Free Lunch: On the Hardness of Choosing a Correct Big-M in Bilevel Optimization
One of the most frequently used approaches to solve linear bilevel optimization problems consists in replacing the lower-level problem with its Karush-Kuhn-Tucker (KKT) conditions and by reformulating the KKT complementarity conditions using techniques from mixed-integer linear optimization. The latter step requires to determine some big-M constant in order to bound the lower level's dual feasible set such that no bilevel optimal solution is cut off. In practice, heuristics are often used to find a big-M although it is known that these approaches may fail. In this paper, we consider the hardness of two proxies for the above mentioned concept of a bilevel-correct big-M. First, we prove that verifying that a given big-M does not cut off any feasible vertex of the lower level's dual polyhedron cannot be done in polynomial time unless P = NP. Second, we show that verifying that a given big-M does not cut off any optimal point of the lower level's dual problem is as hard as solving the original bilevel problem.
