Quantification of Root Anatomical Traits in RGP Transgenic Maize Plants Based on Micro-CT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xiaodi Pan
  • Fonction : Auteur
  • PersonId : 1046193
Liming Ma
  • Fonction : Auteur
  • PersonId : 1046194
Ying Zhang
  • Fonction : Auteur
  • PersonId : 1046195
Jinglu Wang
  • Fonction : Auteur
  • PersonId : 1046196
Jianjun Du
  • Fonction : Auteur
  • PersonId : 972175
Xinyu Guo
  • Fonction : Auteur
  • PersonId : 972162
The RGP transgenic plants show good resistance to drought especially reflected in corn yield. However, little is known about root traits which contribute to drought resistance. Here, we characterized root anatomy in the transgenic plants based on micro-CT scanning. Quantitative analysis of root anatomical traits showed that the drought-resistant RGP transgenic plants had larger root and stele cross-sectional areas in the fourth and the fifth whorls of nodal roots. The metaxylem vessel number and total area of metaxylem vessels was higher or larger in the fifth and the sixth whorls of nodal roots from RGP transgenic plants.
478293_1_En_34_Chapter.pdf (396.85 Ko) Télécharger le fichier
hal-02111538 , version 1 (26-04-2019)
Paternité
Xiaodi Pan, Liming Ma, Ying Zhang, Jinglu Wang, Jianjun Du, et al.. Quantification of Root Anatomical Traits in RGP Transgenic Maize Plants Based on Micro-CT. 11th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Aug 2017, Jilin, China. pp.340-346, ⟨10.1007/978-3-030-06179-1_34⟩. ⟨hal-02111538⟩
39 Consultations
10 Téléchargements
