Optimal Transport Applied to Transfer Learning For P300 Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brain Computer Interfaces suffer from considerable cross-session and cross-subject variability, which makes it hard for classification methods to generalize. We introduce a transfer learning method based on regularized discrete optimal transport with class labels in the interest of enhancing the generalization capacity of state-of-the-art classification methods. We demonstrate the potential of this approach by applying it to offline cross-subject transfer learning for the P300-Speller paradigm. We also simulate an online experiment to assess the feasibility of our method. Results show that our method is comparable to-and sometimes even outperforms-session-dependent classification.
GBCIC_2017_paper_75.pdf (1.33 Mo) Télécharger le fichier
hal-01556603 , version 1 (05-07-2017)
  • HAL Id : hal-01556603 , version 1
Nathalie T. H. Gayraud, Alain Rakotomamonjy, Maureen Clerc. Optimal Transport Applied to Transfer Learning For P300 Detection. BCI 2017 - 7th Graz Brain-Computer Interface Conference, Sep 2017, Graz, Austria. pp.6. ⟨hal-01556603⟩
831 Consultations
799 Téléchargements
