Approximation spaces of deep neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We study the expressivity of deep neural networks. Measuring a network's complexity by its number of connections or by its number of neurons, we consider the class of functions for which the error of best approximation with networks of a given complexity decays at a certain rate when increasing the complexity budget. Using results from classical approximation theory, we show that this class can be endowed with a (quasi)-norm that makes it a linear function space, called approximation space. We establish that allowing the networks to have certain types of "skip connections" does not change the resulting approximation spaces. We also discuss the role of the network's nonlinearity (also known as activation function) on the resulting spaces, as well as the role of depth. For the popular ReLU nonlinearity and its powers, we relate the newly constructed spaces to classical Besov spaces. The established embeddings highlight that some functions of very low Besov smoothness can nevertheless be well approximated by neural networks, if these networks are sufficiently deep.
main.pdf (948.29 Ko) Télécharger le fichier
hal-02117139 , version 1 (02-05-2019)
hal-02117139 , version 2 (13-06-2019)
hal-02117139 , version 3 (10-07-2020)
Rémi Gribonval, Gitta Kutyniok, Morten Nielsen, Felix Voigtlaender. Approximation spaces of deep neural networks. 2019. ⟨hal-02117139v1⟩
705 Consultations
1557 Téléchargements
