CSSD: An End-to-End Deep Neural Network Approach to Pedestrian Detection - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
Single Shot Multibox Detector (SSD) provides a powerful framework for detecting objects using a single deep neural network. The detection framework is one of the top object detection algorithms in both accuracy and speed which processes a large set of object locations sampled across an image. However, this framework does not behave well for the task of pedestrian detection since the images in popular pedestrian datasets have multiple objects occlusion problem and contain lots of small objects. In this paper, we incorporate deconvolution and downsampling unit into the SSD framework allowing detection network to recycle feature maps learned from images. The enhanced performance was obtained by changing the structure of classifier network, e.g., by replacing VGGNet with DenseNet. The contribution of this paper is a one-stage approach to compose a single deep neural network for pedestrian detection task in real-time. This approach addresses the typical difficulty of detecting different scale pedestrian at only one layer by providing a novel channel fusion. To solve small objects problem, base network has been replaced with more powerful one. This approach outperforms competing one-single methods on standard Caltech pedestrian dataset benchmark. It is also faster than all the other methods.
474230_1_En_26_Chapter.pdf (475.49 Ko) Télécharger le fichier
Dates and versions
hal-02118815 , version 1 (03-05-2019)
Attribution - CC BY 4.0
Identifiers
Cite
Feifan Wei, Jianbin Xie, Wei Yan, Peiqin Li. CSSD: An End-to-End Deep Neural Network Approach to Pedestrian Detection. 2nd International Conference on Intelligence Science (ICIS), Nov 2018, Beijing, China. pp.245-254, ⟨10.1007/978-3-030-01313-4_26⟩. ⟨hal-02118815⟩
30 View
66 Download
Share
