Debugging of Behavioural Models with CLEAR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a tool for debugging behavioural models being analysed using model checking techniques. It consists of three parts: (i) one for annotating a behavioural model given a temporal formula , (ii) one for visualizing the erroneous part of the model with a specific focus on decision points that make the model to be correct or incorrect, and (iii) one for abstracting counterexamples thus providing an explanation of the source of the bug.
Barbon2019_Chapter_DebuggingOfBehaviouralModelsWi.pdf (744.74 Ko) Télécharger le fichier
hal-02121180 , version 1 (15-05-2019)
Gianluca Barbon, Vincent Leroy, Gwen Salaün. Debugging of Behavioural Models with CLEAR. TACAS 2019 - 25th International Conference on Tools and Algorithms for the Construction and Analysis of Systems, Apr 2019, Prague, Czech Republic. pp.386-392, ⟨10.1007/978-3-030-17462-0_26⟩. ⟨hal-02121180⟩
113 Consultations
70 Téléchargements
