The Study of the Work Parameters of the Corn Harvester Cutter - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
In this paper, the analytical method of multivariate variance is applied to study the function of the various performance factors of the straight-edge cylindrical cutter. Research results indicate that the main factor impacts the model type surface straight blade cylinder type chopped knife is the speed of the blade, and the application of regression analysis method establishes the regression equation of the blade of stem cutting speed and cutting length, cutting speed and stem throwing distance, speed and power consumption. This paper introduces how to choose chopped knife work parameters with the application of these regression equations.
478291_1_En_27_Chapter.pdf (139.51 Ko) Télécharger le fichier
Dates and versions
hal-02124262 , version 1 (09-05-2019)
Attribution
Identifiers
Cite
Zeng-Hui Wang, Yan-Jun Zhao, Yang Liu, Dong-Yan Huang. The Study of the Work Parameters of the Corn Harvester Cutter. 11th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Aug 2017, Jilin, China. pp.293-301, ⟨10.1007/978-3-030-06137-1_27⟩. ⟨hal-02124262⟩
45 View
63 Download
Share
