Power control in parallel symmetric α-stable noise channels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parallel channels form a basic building block for communication systems, including those based on OFDM and CDMA. While parallel Gaussian noise channels have been widely studied, parallel impulsive noise channels have received significantly less attention despite their importance in a range of modern communication systems. In this paper, this problem is addressed and a power allocation strategy is developed for parallel symmetric α-stable noise channels-a key class of impulsive noise channels. We show that our strategy can improve achievable rates by up to a factor of 1.5 over the standard waterfilling algorithm that assumes the noise is Gaussian.
SPAWC_2019_EGAN.pdf (261.97 Ko) Télécharger le fichier
hal-02130226 , version 1 (15-05-2019)
Mauro de Freitas, Malcolm Egan, Laurent Clavier, Anne Savard, Jean-Marie Gorce. Power control in parallel symmetric α-stable noise channels. SPAWC 2019 - 20th IEEE International Workshop on Signal Processing Advances in Wireless Communications, Jul 2019, Cannes, France. p.1 à 5, ⟨10.1109/SPAWC.2019.8815443⟩. ⟨hal-02130226⟩
102 Consultations
376 Téléchargements
