Variations on the Petersen colouring conjecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Variations sur la conjecture de coloration par le graphe de Petersen
The Petersen colouring conjecture states that every bridgeless cubic graph admits an edge-colouring with 5 colours such that for every edge e, the set of colours assigned to the edges adjacent to e has cardinality either 2 or 4 but not 3. We prove that every bridgeless cubic graph G admits an edge-colouring with 4 such that at most 4 |V(G)| / 5 edges do not satisfy the above condition. This bound is tight and the Petersen graph is the only connected graph for which the bound cannot be decreased. We obtain such a 4-edge-colouring by using a carefully chosen subset of edges of a perfect matching, and the analysis relies on a simple discharging procedure with essentially no reductions and very few rules.
pss18.pdf (206.2 Ko) Télécharger le fichier
hal-02133840 , version 1 (20-05-2019)
hal-02133840 , version 2 (07-12-2020)
  • HAL Id : hal-02133840 , version 1
François Pirot, Jean-Sébastien Sereni, Riste Škrekovski. Variations on the Petersen colouring conjecture. 2018. ⟨hal-02133840v1⟩
63 Consultations
97 Téléchargements
