On a one dimensional turbulent boundary layer model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
This paper is devoted to the study of a one stationary dimensional turbulence model used for simulating the boundary layer of a turbulent flow, such as the atmospheric boundary layer. The model is based on the coupling of an equation for the mean velocity with an equation for the turbulent kinetic energy through eddy viscosities. We show that under reasonable assumptions about the data, the system has a weak solution.
NSTKE_1D_3.pdf (327.94 Ko) Télécharger le fichier
hal-02134034 , version 1 (20-05-2019)
hal-02134034 , version 2 (19-11-2019)
  • HAL Id : hal-02134034 , version 1
Roger Lewandowski. On a one dimensional turbulent boundary layer model. 2019. ⟨hal-02134034v1⟩
196 Consultations
243 Téléchargements
