Salvage of congenital pseudarthrosis of the tibia by the induced membrane technique followed by a motorised lengthening nail - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Orthopaedics & Traumatology: Surgery & Research Année : 2018
An 18-year-old male with neurofibromatosis type I was treated for congenital pseudarthrosis of the tibia using the Masquelet induced-membrane technique with internal fixation by retrograde implantation of a transplantar intramedullary nail. Bone healing was obtained at the expense of malunion with external rotation and 5.5cm of lower limb shortening. A motorised intramedullary-lengthening nail (Fitbone®, Wittenstein, Igersheim, Germany) was implanted. This treatment was successful in correcting the rotational malalignment and limb length discrepancy. The motorised nail Fitbone® may be a valid option for treating complex cases of limb length discrepancy, including those combined with limb deformities.
Pollon_23116.pdf (1.4 Mo) Télécharger le fichier
hal-02135146 , version 1 (21-05-2019)
Tristan Pollon, Jérôme Sales de Gauzy, Thuy Trang Pham, Camille Thevenin Lemoine, Franck Accadbled. Salvage of congenital pseudarthrosis of the tibia by the induced membrane technique followed by a motorised lengthening nail. Orthopaedics & Traumatology: Surgery & Research, 2018, 104 (1), pp.147-153. ⟨10.1016/j.otsr.2017.10.012⟩. ⟨hal-02135146⟩
47 Consultations
38 Téléchargements
