P-Band SAR tomography for the characterization of tropical forests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The objective of this paper is to provide a better understanding of tomographic capabilities in characterization of dense forested areas at P-band. The analysis is carried out on airborne data acquired by ONERA over the site in French Guyana, and in Gabon during the ESA campaign TropiSAR 2009 and AfriSAR 2015, respectively. The results shown support the idea that ground- and -volume interactions play a significant role at P-band. For a dense forest of 30 m and more, strong ground contribution at P-band can be visible in tomograms. P-band tomography allow us to retrieve the whole forest vertical structure, better characterizing of the ground and/or volume scatterings and providing an unique solution in high biomass ranging from 0-500 t/ha.
Fichier non déposé
hal-02608059 , version 1 (16-05-2020)
Dinh Ho Tong Minh, Ludovic Villard, Laurent Ferro-Famil, S. Tebaldini, Thuy Le Toan. P-Band SAR tomography for the characterization of tropical forests. IGARSS 2017 - 2017 IEEE International Geoscience and Remote Sensing Symposium, Jul 2017, Fort Worth, United States. pp.5862-5865, ⟨10.1109/IGARSS.2017.8128342⟩. ⟨hal-02608059⟩
108 Consultations
0 Téléchargements
