Boundary controllability of the Korteweg-de Vries equation on a tree-shaped network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Controllability of coupled systems is a complex issue depending on the coupling conditions and the equations themselves. Roughly speaking, the main challenge is controlling a system with less inputs than equations. In this paper this is successfully done for a system of Korteweg-de Vries equations posed on an oriented tree shaped network. The couplings and the controls appear only on boundary conditions.
cerpa-crepeau-valein.pdf (332.06 Ko) Télécharger le fichier
hal-02137907 , version 1 (23-05-2019)
hal-02137907 , version 2 (10-09-2020)
  • HAL Id : hal-02137907 , version 1
Eduardo Cerpa, Emmanuelle Crépeau, Julie Valein. Boundary controllability of the Korteweg-de Vries equation on a tree-shaped network. 2019. ⟨hal-02137907v1⟩
172 Consultations
206 Téléchargements
