A non-local traffic flow model for 1-to-1 junctions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Applied Mathematics Année : 2020
We present a model for a class of non-local conservation laws arising in traffic flow modeling at road junctions. Instead of a single velocity function for the whole road, we consider two different road segments, which may differ for their speed law and number of lanes (hence their maximal vehicle density). We use an upwind type numerical scheme to construct a sequence of approximate solutions and we provide uniform L∞ and total variation estimates. In particular, the solutions of the proposed model stay positive and below the maximum density of each road segment. Using a Lax-Wendroff type argument and the doubling of variables technique, we prove the well-posedness of the proposed model. Finally, some numerical simulations are provided and compared with the corresponding (discontinuous) local model.
Non-localJunction.pdf (545.85 Ko) Télécharger le fichier
hal-02142345 , version 1 (28-05-2019)
hal-02142345 , version 2 (02-12-2019)
  • HAL Id : hal-02142345 , version 2
Felisia Angela A Chiarello, Jan Friedrich, Paola Goatin, Simone Göttlich, Oliver Kolb. A non-local traffic flow model for 1-to-1 junctions. European Journal of Applied Mathematics, 2020, 31 (6), pp.1029-1049. ⟨hal-02142345v2⟩
597 Consultations
306 Téléchargements
