A variational formulation for coupled degenerate elliptic equations with different signs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We study a coupling of two degenerate elliptic equations in 2D with a smooth sign changing coefficient and compact terms. The degeneracy of the coefficient is critical with respect to the theory of weighted Sobolev spaces. An adapted functional framework is proposed for the description of the solution in the context of the limit absorption principle. It leads to a new well-posed mixed variational formulation. Numerical experiments illustrate the stability of our formulation.
article_2DXmode.pdf (871.52 Ko) Télécharger le fichier
hal-02142631 , version 1 (28-05-2019)
hal-02142631 , version 2 (19-07-2019)
  • HAL Id : hal-02142631 , version 1
Anouk Nicolopoulos, Martin Campos Pinto, Bruno Després, Patrick Ciarlet. A variational formulation for coupled degenerate elliptic equations with different signs. 2019. ⟨hal-02142631v1⟩
263 Consultations
369 Téléchargements
