Explicit degree bounds for right factors of linear differential operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
If a linear differential operator with rational function coefficients is reducible, its factors may have coefficients with numerators and denominators of very high degree. When the base field is $\mathbb C$, we give a completely explicit bound for the degrees of the monic right factors in terms of the degree and the order of the original operator, as well as the largest modulus of the local exponents at all its singularities. As a consequence, if a differential operator $L$ has rational function coefficients over a number field, we get degree bounds for its monic right factors in terms of the degree, the order and the height of $L$, and of the degree of the number field.
factorisation.pdf (188.03 Ko) Télécharger le fichier
hal-02154679 , version 1 (12-06-2019)
hal-02154679 , version 2 (20-06-2019)
hal-02154679 , version 3 (10-07-2019)
hal-02154679 , version 4 (03-06-2020)
Alin Bostan, Tanguy Rivoal, Bruno Salvy. Explicit degree bounds for right factors of linear differential operators. 2019. ⟨hal-02154679v3⟩
460 Consultations
264 Téléchargements
