Global optimization of metasurface designs using statistical learning methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Optimization of the performance of flat optical components, also dubbed metasurfaces, is a crucial step towards their implementation in realistic optical systems. Yet, most of the design techniques, which rely on large parameter search to calculate the optical scattering response of elementary building blocks, do not account for near-field interactions that strongly influence the device performance. In this work, we exploit two advanced optimization techniques based on statistical learning and evolutionary strategies together with a fullwave high order Discontinuous Galerkin Time-Domain (DGTD) solver to optimize phase gradient metasurfaces. We first review the main features of these optimization techniques and then show that they can outperform most of the available designs proposed in the literature. Statistical learning is particularly interesting for optimizing complex problems containing several global minima/maxima. We then demonstrate optimal designs for GaN semiconductor phase gradient metasurfaces operating at visible wavelengths. Our numerical results reveal that rectangular and cylindrical nanopillar arrays can achieve more than respectively 88% and 85% of diffraction efficiency for TM polarization and both TM and TE polarization respectively, using only 150 fullwave simulations. To the best of our knowledge, this is the highest blazed diffraction efficiency reported so far at visible wavelength using such metasurface architectures.
Hal_v2_optimizations_July.pdf (6.08 Mo) Télécharger le fichier
hal-02156881 , version 1 (14-06-2019)
hal-02156881 , version 2 (27-07-2019)
hal-02156881 , version 3 (01-12-2019)
  • HAL Id : hal-02156881 , version 2
Mahmoud M R Elsawy, Stéphane Lanteri, Régis Duvigneau, Mohamed Sabry Mohamed, Gauthier Brière, et al.. Global optimization of metasurface designs using statistical learning methods. 2019. ⟨hal-02156881v2⟩
650 Consultations
389 Téléchargements
