The hydroxymethylome of multiple myeloma identifies FAM72D as a 1q21 marker linked to proliferation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Haematologica Année : 2020
Nicolas Robert
  • Fonction : Auteur
Cell identity relies on the cross-talk between genetics and epigenetics and their impact on gene expression. Oxidation of 5-methylcytosine (5mC) into 5-hydroxymethylcytosine (5hmC) is the first step of an active DNA demethylation process occurring mainly at enhancers and gene bodies and, as such, participates in processes governing cell identity in normal and pathological conditions. Although genetic alterations are well documented in multiple myeloma (MM), epigenetic alterations associated with this disease have not yet been thoroughly analyzed. To gain insight into the biology of MM, genome-wide 5hmC profiles were obtained and showed that regions enriched in this modified base overlap with MM enhancers and super enhancers and are close to highly expressed genes. Through the definition of a MM-specific 5hmC signature, we identified FAM72D as a poor prognostic gene located on 1q21, a region amplified in high risk myeloma. We further uncovered that FAM72D functions as part of the FOXM1 transcription factor network controlling cell proliferation and survival and we evidenced an increased sensitivity of cells expressing high levels of FOXM1 and FAM72 to epigenetic drugs targeting histone deacetylases and DNA methyltransferases.
Chatonnet_et al_Hydroxymethylome of multiple myeloma_accepted.pdf (484.11 Ko) Télécharger le fichier
hal-02165596 , version 1 (18-10-2019)
Copyright (Tous droits réservés)
Fabrice Chatonnet, Amandine Pignarre, Aurelien Serandour, Gersende Caron, Stéphane Avner, et al.. The hydroxymethylome of multiple myeloma identifies FAM72D as a 1q21 marker linked to proliferation. Haematologica, 2020, 105 (3), pp.774-783. ⟨10.3324/haematol.2019.222133⟩. ⟨hal-02165596⟩
249 Consultations
82 Téléchargements
