Formal Proof and Analysis of an Incremental Cycle Detection Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study a state-of-the-art incremental cycle detection algorithm due to Bender, Fineman, Gilbert, and Tarjan. We propose a simple change that allows the algorithm to be regarded as genuinely online. Then, we exploit Separation Logic with Time Credits to simultaneously verify the correctness and the worst-case amortized asymptotic complexity of the modified algorithm.
main.pdf (539.21 Ko) Télécharger le fichier
hal-02167236 , version 1 (27-06-2019)
  • HAL Id : hal-02167236 , version 1
Armaël Guéneau, Jacques-Henri Jourdan, Arthur Charguéraud, François Pottier. Formal Proof and Analysis of an Incremental Cycle Detection Algorithm: (extended version). Interactive Theorem Proving, Sep 2019, Portland, United States. ⟨hal-02167236⟩
318 Consultations
491 Téléchargements
