Synchronization at thread and execution termination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
Whereas its intent is clear, the C standard lacks clarity concerning synchronization guarantees for the interaction of call backs that may be called during thread termination and during the termination of the whole program execution.
n2461+appendix.pdf (313.06 Ko) Télécharger le fichier
hal-02167850 , version 1 (28-06-2019)
hal-02167850 , version 2 (25-11-2019)
  • HAL Id : hal-02167850 , version 2
Jens Gustedt. Synchronization at thread and execution termination: proposal for integration to C2x. [Research Report] N2461, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167850v2⟩
38 Consultations
135 Téléchargements
