The Impact of Sample Volume in Random Search on the bbob Test Suite
Uniform Random Search is considered the simplest of all randomized search strategies and thus a natural baseline in benchmarking. Yet, in continuous domain it has its search domain width as a parameter that potentially has a strong effect on its performance. In this paper, we investigate this effect on the well-known 24 functions from the bbob test suite by varying the sample domain of the algorithm ([−α, α]^n for α ∈ {0.5, 1, 2, 3, 4, 5, 6, 10, 20} and n the search space dimension). Though the optima of the bbob testbed are randomly chosen in [−4, 4]^n (with the exception of the linear function f5), the best strategy depends on the search space dimension and the chosen budget. Small budgets and larger dimensions favor smaller domain widths.
Réseau de neurones [cs.NE]
