Avoiding observability singularities in output feedback bilinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2021
Control-affine output systems generically present observability singularities, i.e. inputs that make the system unobservable. This proves to be a difficulty in the context of output feedback stabilization, where this issue is usually discarded by uniform observability assumptions for state feedback stabilizable systems. Focusing on state feedback stabilizable bilinear control systems with linear output, we use a transversality approach to provide perturbations of the stabilizing state feedback law, in order to make our system observable in any time even in the presence of singular inputs.
mainv2.pdf (316.99 Ko) Télécharger le fichier
hal-02172420 , version 1 (03-07-2019)
hal-02172420 , version 2 (12-01-2021)
Lucas Brivadis, Jean-Paul Gauthier, Ludovic Sacchelli, Ulysse Serres. Avoiding observability singularities in output feedback bilinear systems. SIAM Journal on Control and Optimization, 2021, 59 (3), pp.1759-1780. ⟨10.1137/19M1272925⟩. ⟨hal-02172420v2⟩
474 Consultations
254 Téléchargements
