Tracking of Non-Rigid Objects using RGB-D Camera - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A method to accurately track deformable objects using a RGB-D camera with the help of a coarse object model is presented in this paper. The deformation model is based on corotational FEM formulation. The physical model of the object does not need to be exact, nor do we require the precise physical properties for accurately tracking the object. The position of the vertices of the surface mesh of the tracked object is deformed using a set of virtual forces. A point-to-plane distance based geometric error between the pointcloud and the mesh is minimized with respect to these virtual forces. The point of application of force is determined by analysis of the error obtained from rigid tracking, which is done in parallel with the non-rigid tracking. This architecture also enables the overall system to be realtime. The proposed approach is evaluated on a synthetic data with ground-truth for deformation at every frame, as well as on real data.
SMC19_0740_FI.pdf (1.1 Mo) Télécharger le fichier
hal-02178353 , version 1 (09-07-2019)
hal-02178353 , version 2 (08-08-2019)
Agniva Sengupta, Alexandre Krupa, Eric Marchand. Tracking of Non-Rigid Objects using RGB-D Camera. SMC 2019 - IEEE International Conference on Systems, Man, and Cybernetics, Oct 2019, Bari, Italy. pp.3310-3317, ⟨10.1109/SMC.2019.8914543⟩. ⟨hal-02178353v2⟩
187 Consultations
674 Téléchargements
