Kinematic Simulation of Vibrating Disc No-Till Seeder Based on Creo Software - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
In order to solve the problems of wheat no-till seeders in annual double cropping area of North China Plain such as large amount of straw-covering, stubble-bulky, residue-blocking, and bad passing capacity and planting quality, the new vibrating disc no-till seeder was designed. This paper analyzed the structure and elaborated the working principle. Creo software was used to establish three-dimensional motion simulation model, and add the constraints of seeder’s parts to realize the movement of seeder and its anti-blocking device. The change of displacement, velocity and acceleration of vibrating disc was obtained by simulation. The result showed that there was no collision between components of the seeder, and the main circular motion occurred in y direction, which was beneficial to cut the straw. The study provides theoretical basis for the trajectory optimization and dynamics simulation analysis of vibrating disc no-till seeder in the future.
478221_1_En_13_Chapter.pdf (713.51 Ko) Télécharger le fichier
Dates and versions
hal-02179979 , version 1 (12-07-2019)
Attribution
Identifiers
Cite
Caiyun Lu, Zhijun Meng, Xiu Wang, Guangwei Wu, Liwei Li, et al.. Kinematic Simulation of Vibrating Disc No-Till Seeder Based on Creo Software. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.134-142, ⟨10.1007/978-3-030-06155-5_13⟩. ⟨hal-02179979⟩
56 View
39 Download
Share
