Application of “GaoFen-1” Satellite Data and “Micro-UAV” Data in Remote Sensing Monitoring in Winter Wheat—Illustrated by a Case of Jizhou in Hebei Province - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2019
This research utilized “GaoFen-1” 2 m panchromatic, 8 m and 16 m multispectral satellite data to monitor the planting area of winter wheat. Calculate the correction coefficient by the results of planting area of winter wheat gotten from “GaoFen-1” 16 m multispectral satellite data and micro unmanned aerial vehicle data. Correct the area extraction result of “GaoFen-1” 16 m multispectral satellite data and verify the accuracy of the results got from fusion data of 2 m resolution and 8 m resolution of “GaoFen-1” by micro unmanned aerial vehicle data. Then compare with the area extraction results, extracted from the data of fusion data of 2 m resolution and 8 m resolution of “GaoFen-1” and the corrected 16 m multispectral satellite data, in Jizhou. The study result show that the corrected extraction result of planting area of winter wheat, from “GaoFen-1” 16 m multispectral satellite data, is accurate relatively and could better meet the requirements of the crop dynamic monitoring business operational running.
478221_1_En_3_Chapter.pdf (708.98 Ko) Télécharger le fichier
Dates and versions
hal-02179988 , version 1 (12-07-2019)
Attribution
Identifiers
Cite
Yuechen Liu, Weijie Jiao, Haijun Wang, Xue Han. Application of “GaoFen-1” Satellite Data and “Micro-UAV” Data in Remote Sensing Monitoring in Winter Wheat—Illustrated by a Case of Jizhou in Hebei Province. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.20-29, ⟨10.1007/978-3-030-06155-5_3⟩. ⟨hal-02179988⟩
67 View
25 Download
Share
