Extended McKean-Vlasov optimal stochastic control applied to smart grid management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2022
We study the mathematical modeling of the energy management system of a smart grid, related to a aggregated consumer equipped with renewable energy production (PV panels e.g.), storage facilities (batteries), and connected to the electrical public grid. He controls the use of the storage facilities in order to diminish the random fluctuations of his residual load on the public grid, so that intermittent renewable energy is better used leading globally to a much greener carbon footprint. The optimization problem is described in terms of an extended McKean-Vlasov stochastic control problem. Using the Pontryagin principle, we characterize the optimal storage control as solution of a certain McKean-Vlasov Forward Backward Stochastic Differential Equation (possibly with jumps), for which we prove existence and uniqueness. Quasi-explicit solutions are derived when the cost functions may not be linear- quadratic, using a perturbation approach. Numerical experiments support the study.
article_engagement_mckean.pdf (681.14 Ko) Télécharger le fichier
hal-02181227 , version 1 (12-07-2019)
hal-02181227 , version 2 (12-01-2021)
Emmanuel Gobet, Maxime Grangereau. Extended McKean-Vlasov optimal stochastic control applied to smart grid management. ESAIM: Control, Optimisation and Calculus of Variations, 2022, 28, pp.40. ⟨10.1051/cocv/2022034⟩. ⟨hal-02181227v2⟩
392 Consultations
628 Téléchargements
