Neural network regression for Bermudan option pricing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2021
The pricing of Bermudan options amounts to solving a dynamic programming principle, in which the main difficulty, especially in high dimension, comes from the conditional expectation involved in the computation of the continuation value. These conditional expectations are classically computed by regression techniques on a finite dimensional vector space. In this work, we study neural networks approximations of conditional expectations. We prove the convergence of the well-known Longstaff and Schwartz algorithm when the standard least-square regression is replaced by a neural network approximation. We illustrate the numerical efficiency of neural networks as an alternative to standard regression methods for approximating conditional expectations on several numerical examples.
ls-nn.pdf (303.75 Ko) Télécharger le fichier
hal-02183587 , version 1 (15-07-2019)
hal-02183587 , version 2 (10-12-2019)
hal-02183587 , version 3 (27-11-2020)
Bernard Lapeyre, Jérôme Lelong. Neural network regression for Bermudan option pricing. Monte Carlo Methods and Applications, 2021, 27 (3), pp.227-247. ⟨10.1515/mcma-2021-2091⟩. ⟨hal-02183587v3⟩
777 Consultations
1624 Téléchargements
