Modelling the genesis of equatorial podzols: age and implications for carbon fluxes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biogeosciences Année : 2017
Amazonian podzols store huge amounts of carbon and play a key role in transferring organic matter to the Amazon River. In order to better understand their C dynamics, we modelled the formation of representative Amazonian pod-zol profiles by constraining both total carbon and radiocar-bon. We determined the relationships between total carbon and radiocarbon in organic C pools numerically by setting constant C and 14 C inputs over time. The model was an effective tool for determining the order of magnitude of the carbon fluxes and the time of genesis of the main carbon-containing horizons, i.e. the topsoil and deep Bh. We performed retrocalculations to take into account the bomb carbon in the young topsoil horizons (calculated apparent 14 C age from 62 to 109 years). We modelled four profiles representative of Amazonian podzols, two profiles with an old Bh (calculated apparent 14 C age 6.8 × 10 3 and 8.4 × 10 3 years) and two profiles with a very old Bh (calculated apparent 14 C age 23.2 × 10 3 and 25.1 × 10 3 years). The calculated fluxes from the topsoil to the perched water table indicate that the most waterlogged zones of the podzolized areas are the main source of dissolved organic matter found in the river network. It was necessary to consider two Bh carbon pools to accurately represent the carbon fluxes leaving the Bh as observed in previous studies. We found that the genesis time of the studied soils was necessarily longer than 15 × 10 3 and 130 × 10 3 years for the two younger and two older Bhs, respectively , and that the genesis time calculated considering the more likely settings runs to around 15 × 10 3-25 × 10 3 and 150 × 10 3-250 × 10 3 years, respectively.
Doupoux et al 2017 Biogeosciences.pdf (4.8 Mo) Télécharger le fichier
hal-02184058 , version 1 (15-07-2019)
Cédric Doupoux, Patricia Merdy, Célia Regina Montes, Naoise Nunan, Adolpho José Melfi, et al.. Modelling the genesis of equatorial podzols: age and implications for carbon fluxes. Biogeosciences, 2017, 14 (9), pp.2429-2440. ⟨10.5194/bg-14-2429-2017⟩. ⟨hal-02184058⟩
100 Consultations
37 Téléchargements
