Comparison of Polycyclic Aromatic Hydrocarbon (PAHs) concentrations in urban and natural forest soils in the Atlantic Forest (São Paulo State) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Anais da Academia Brasileira de Ciências Année : 2009
Studies about pollution by Polycyclic Aromatic Hydrocarbons (PAHs) in tropical soils and Brazil are scarce. A study was performed to examine the PAHs composition, concentrations and sources in red-yellow Oxisols of remnant Atlantic Forest of the São Paulo State. Sampling areas were located in an urban site (PEFI) and in a natural one (CUNHA). The granulometric composition, pH, organic matter content and mineralogical composition were determined in samples of superficial soils. The sum of PAHs (HPAs) was 4.5 times higher in the urban area than in the natural one. Acenaphthylene, acenaphthene, fluorene, phenanthrene and fluoranthene have been detected in the soils of both areas and presented similar concentrations. Acenaphthene and fluorene were the most abundant compounds. Pyrene was twice more abundant in the soils of natural area (15 µg.kg-1) than of the urban area and fluoranthene was the dominant compound (203 µg.kg-1) in urban area (6.8 times higher than in the natural area). Some compounds of higher molecular weight, which are tracers of vehicular emissions showed significant concentrations in urban soils. Pyrene represented 79% of PAHs whereas it has not been detected in natural soils. The results showed that forest soils in urban area are characterized by the accumulation of high molecular weight compounds of industrial and vehicular origin.
Bourotte et al 2009 Anais Acad Bras Ci.pdf (267.52 Ko) Télécharger le fichier
hal-02185637 , version 1 (16-07-2019)
Christine Bourotte, Maria Cristina Forti, Yves Lucas, Adolpho José Melfi. Comparison of Polycyclic Aromatic Hydrocarbon (PAHs) concentrations in urban and natural forest soils in the Atlantic Forest (São Paulo State). Anais da Academia Brasileira de Ciências, 2009, 81 (1), pp.127-136. ⟨10.1590/S0001-37652009000100013⟩. ⟨hal-02185637⟩
Collections
UNIV-TLN PROTEE
65 Consultations
42 Téléchargements
