Two-level preconditioning for h-version boundary element approximation of hypersingular operator with GenEO - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2020
In the present contribution, we consider symmetric positive definite operators stemming from boundary integral equation (BIE), and we study a two-level preconditioner where the coarse space is built using local generalized eigenproblems in the overlap. We will refer to this coarse space as the GenEO coarse space.
main.pdf (1.07 Mo) Télécharger le fichier
hal-02188771 , version 1 (18-07-2019)
Pierre Marchand, Xavier Claeys, Pierre Jolivet, Frédéric Nataf, Pierre-Henri Tournier. Two-level preconditioning for h-version boundary element approximation of hypersingular operator with GenEO. Numerische Mathematik, 2020, 146, pp.597-628. ⟨10.1007/s00211-020-01149-5⟩. ⟨hal-02188771⟩
348 Consultations
1325 Téléchargements
