A Plug and Play Integration Model for Virtual Enterprises - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Juan D. Méndez
  • Fonction : Auteur
  • PersonId : 1051243
Ricardo J. Rabelo
  • Fonction : Auteur
  • PersonId : 991477
Fabiano Baldo
  • Fonction : Auteur
  • PersonId : 1051244
Maiara H. Cancian
  • Fonction : Auteur
  • PersonId : 1025706
Systems integration is a key issue to be faced when supporting Virtual Enterprises (VE) execution. However, it is very complex regarding the dynamic composition, autonomy and large distribution of its members as well as the high heterogeneity of IT and business processes’ models used by them. It has been realized by many works in the literature that SMEs should have some preparedness, including at the IT level, in order to create a feasible solution for them to get onboard and agilely interoperate in real VEs. This work intends to overcome some drawbacks of current approaches for that, proposing a model where VE partners can more easily get into a VE when it is created (plug) so that the VE can be executed seamlessly during its operation (play) and dissolution (unplug), including the support of some level of semantic interoperability. A prototype has been implemented, and results are discussed.
472393_1_En_27_Chapter.pdf (596.12 Ko) Télécharger le fichier
hal-02191181 , version 1 (24-07-2019)
Paternité
Juan D. Méndez, Ricardo J. Rabelo, Fabiano Baldo, Maiara H. Cancian. A Plug and Play Integration Model for Virtual Enterprises. 19th Working Conference on Virtual Enterprises (PRO-VE), Sep 2018, Cardiff, United Kingdom. pp.312-324, ⟨10.1007/978-3-319-99127-6_27⟩. ⟨hal-02191181⟩
41 Consultations
74 Téléchargements
