A numerical analysis focused comparison of several Finite Volume schemes for an Unipolar Degenerated Drift-Diffusion Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In this paper, we consider an unipolar degenerated drift-diffusion system where the relation between the concentration of the charged species c and the chemical potential h is h(c) = log c 1−c. We design four different finite volume schemes based on four different formulations of the fluxes. We provide a stability analysis and existence results for the four schemes. The convergence proof with respect to the discretization parameters is established for two of them. Numerical experiments illustrate the behaviour of the different schemes.
CCFG_ionic.pdf (2.87 Mo) Télécharger le fichier
hal-02194604 , version 1 (25-07-2019)
hal-02194604 , version 2 (25-07-2019)
hal-02194604 , version 3 (19-12-2019)
  • HAL Id : hal-02194604 , version 1
Clément Cancès, Claire Chainais-Hillairet, Jürgen Fuhrmann, Benoît Gaudeul. A numerical analysis focused comparison of several Finite Volume schemes for an Unipolar Degenerated Drift-Diffusion Model. 2019. ⟨hal-02194604v1⟩
370 Consultations
269 Téléchargements
